Wishes
Command to toggle Associative/Independent Labels
jakubc7
Right now there seems to be no way to assign a keyboard shortcut to toggle between Associative and Independent labels.
This is a suggestion from laszlonagy posted on original thread:
http://archicad-talk.graphisoft.com/viewtopic.php?t=56117
"The Geometry panel of the Label Tool has two buttons, both have two states.
So the G shortcut key should have these four states:
Associative + Simple
Associative + Detailed
Independent + Simple
Independent + Detailed
Then you could use the G key to cycle through 4 four combinations"
I think this is a no brainier. I assign shortcuts to pretty much any command I use more than once a day so this one really frustrates me. It is also worth noting that favourites currently do not retain this property either.
ArchiCAD 10 - 25 | Windows 10
ARCHIcreate | Perth, Western Australia
archicad solutions | content creation | training | software implementation
0 REPLIES 0
Learn and get certified!
