Wall clean up on composite walls is less than desirable. Composite elements, like layers, need to have settable levels, a hierarchy if you will. That way a 2x element will clean up to a 2x, a gyp element to gyp, air space to air space....., and so on. That way each element will clean up appropriately instead of from inside to outside corner which allows "bleeding" of elements.
