2023-03-14 05:18 PM
Hi!
I use the Solid Element Operations a lot for modelling roads, sidewalks and other landscape parts. However, this slows down the model quite a lot, so I like to convert them to morphs, and keep the SEO as a backup for when I need to change things. Especially elements like sidewalks are good for this, so I can move them in Z to create a difference between road and sidewalk.
However, when using the Convert Selection to Morph, I use all SEO:s. To have a Convert Copy of Selection to Morph button in the right click menu would be a wonderful timesaver, which would leave me with a morph as well as the original elements, still with the SEO:s active.
Thank you
Kaj
