Wishes
Detail Tool( Further improve the Detail Tool)
---Z---
I hope to further improve the AC Detail Tool. It has reached the 26th version, but the Detail Tool is still not easy to use and practical. You want to refer to the Detail index Tool in Revit.
4 REPLIES 4
---Z---
AC Detail Tool Marker Detail cannot create window maps that directly contact the main model, such as Section Tool&Elevation Tool. It does not carry axis numbers. It is still a semi-finished tool.
---Z---
The callout tool in Revit is reasonable, and it is also a view tool for our general needs. AC Detail Tool=Revit detail index tool. The view generated in this tool is connected with the main model, and it is correct to automatically produce the grid. I think for AC, the function of developing this tool should not be a problem. Why hasn't it been solved.
gavinNZz
The detail tool is the most old fashioned toiol in the AC software. I highlighted this a while back in the post below and proposed a '3D detail bounding box' be developed that would be a live view from the 3D model with the 6 2D views nested under it like the interior elevation tool works. I feel that I will have probably stopped using AC before this will ever be developed tho!
https://community.Graphisoft.com/t5/Wishes-forum/3D-Detail-Bounding-Box/td-p/330837
Planworks Ltd
Residential Designer based in Tauranga, NZ
Archicad v9+
VR enthusiast.
Always wants more!
Benjamin Dani
Dear All,
Thank you for sharing your ideas and opinions regarding this request!
I'm glad to say that we took notice and we have added this wish into our Wish list database.
(For future reference, you can refer to it as IDEA-12353)
I hope we see this get implemented in the future.
Have a great day!
Best regards,
Dani Benjamin
Technical Support Engineer
Learn and get certified!
