Read more
Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Detail Within Detail
I made a Detail, using the Detail tool, of a wall section. From within this detail, I need to use another Detail marker to reference to a roof detail. When I'm in the Detail of the Wall Section, the Detail tool is greyed-out/inaccessible. I can make a work-around, but I need to be able to use the Detail tool within a Detail.
Thanks.
Yes this would be very helpful!
At the moment to do this I have to resort to 2D detail marking and manual referencing, shock horror!!
Why don't you use section/elevation tool for wall section (unlink from model as needed) and detail within the section ?
