Wishes
Dimensions
jclewis
It would be very useful if we could assign different pens and linetypes to both the dimension line and the leader lines.
James C Lewis
AC 24 (Full)
Mac Pro (Late 2013) OS 10.13.5
7 REPLIES 7
Dave Jochum
I'm not sure how I'd use different line weights, but line types would be very useful. I've never liked having to draw a separate centerline as a dimension leader.
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 13.2.1•AC 26 Silicon (latest build)
And how about "arrowheads" too. When the line is a centerline the arrowhead should be a circle.
Laura Yanoviak
This is an old thread, but I will add my 2 cents:
Typically, the extension lines of a dimension string (I believe they are called "witness lines" in AC) have a finer lineweight than the dimension line, so it would be convenient to be able to control the pens of each.
Controlling the linetype of the extension lines (the aforementioned center line) would be VERY helpful.
Also, the ability to use different arrowheads (a dot at center lines and/or grid lines) could be useful -- and the capacity to create custom arrowheads would be ideal!
MacBook Pro 2.4 GHz Intel Core i9, 32 GB of RAM
AC25 US (3011) AC24 on Mac OS Catalina 10.15.7
How abuot an option for popup selecting vertical/horizontal/aligned after "hammer click"? Or manually track dimension alignement after "hammer click"
Ben Cohen
Rolling Eyes
nice one, but how about after the hammer, left click - vertical, right click - horizontal and centre click aligned? That would be cool
Ben Cohen
Mac and PC
Archicad (Latest Version) aus
www.4DLibrary.com.au
yeah, baby, or just (hammer) click then shift-click up (or down) for vert, left or right for horiz, align for aligned.....instead of just the one point. And be able to change your mind if you do the wrong one!
Ben Cohen
Aladino I think you should create another, separate wish for this one
Ben Cohen
Mac and PC
