Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Door Height Issue
I am not sure why this changed from ArchiCAD 7 to ArchiCAD 8 but shouldn't the threshold of the door remain at the same level when changing a doors height and have the head height vary? For example, when you change a 6'-8" door to a 7'-0" door the threshold changes to -4". You then have to change a second parameter of the door to get it in the correct position. This is a complete waste of time and to me totally counter intuitive.
An argument can be made that windows should behave this way but for doors it's kind of ridiculous.
Aussie John
Michael there is a preference ( construction method) which controls this.
I agree a little lock symbol next to the sill/head adjustment would be nice for window adjustments so the method could be change on the fly
Cheers John
[/size]
Aussie John, thanks for the info about the preference. I did not see it before. It would be nice if there were separate preferences for doors and windows to better mirror the way people work or a toggle to change it on the fly as you suggested.
