Read more
Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Doors & Windows Enhancements
Here is another wish
I'd like to see an option for custom profile door and window casings; because flat casings are rarely used in real life construction. Also, I'd like to see the handle outside and inside option back in the INT version. I had a highly customised project where door handles were different on each side of the door, not to mention there was a different face for the leaf on each side (which could be achieved by a custom leaf of course).
DGSketcher
Legend
I can see this coming in the future as computing power increases but for now it could add a significant model load without much visual gain depending on what scale or how zoomed in you are to your model.
David Maudlin
With the addition of Custom Profiles to GDL, this is now possible; the library developers will need to code it.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
