Read more
Wishes
Editing Vector images in ArchiCAD?
Gus
I have been trying to figure out how to get a vector image into ArchiCAD so I can edit it using ArchiCAD's editing tools. I can get an image into ArchiCAD but I can't "explode" it so that the vector shapes can be edited. Has anyone out there ever done this?
-Michael
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W Corei7-3630QM@2.40GHz
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
3 REPLIES 3
PDF?
Think Like a Spec Writer
AC4.55 through 27 / USA AC27-4060 USA
Rhino 8 Mac
MacOS 14.2.1
Gus
I understand that a pdf is a vecor image, but how do you explode that pdf so you can actually edit those vectors? Does it have something to do with the way you import the pdf?
Madison WI
A PDF is not always a vector file.
It depends on what software it was created with.
Archicad 18 now has the ability to explode a PDF and if it was based on a vector file you will get vector elements you can edit.
Simply place the PDF with the Drawing tool in your plan and then select and explode.
