2005-03-03 01:12 AM
2005-03-03 03:06 AM
2005-03-03 07:31 AM
johncassel wrote:John,
We place detailed, scaled drawings into ArchiCAD via the Figure Tool.
2005-03-03 07:57 PM
Ben wrote:Ben,
I'd really like to hear the process you use to get scaled images. What program do you use? How accurate is it? I have never been able to get a rasterized image to be exactly 100% to scale.
Ben
2005-03-03 09:39 PM
2005-03-03 09:48 PM
johncassel wrote:John,Ben wrote:Ben,
Ben
I am only using these drawings as an underlay as a guide for creating an accurate model in ArchiCAD. The first step is to put a graphic scale on the drawing. Next the scaled drawing is scanned using a Mustek 11"x17" scanner. You can buy the Mustek ScanExpress A3 USB on Amazon for $156 and they pay for the shipping.
If the drawing is larger than 11"x17" I open it in Photoshop and paste the scans together into one large image. I allow for a good bit of overlap as the edges of the scan are sometimes not as accurate as the main body of the scan. Registration here is a bit of trick that takes a bit of doing. Photoshop is a good tool for rotating the drawing so that the vertical lines are at 90 degrees.
The drawing is saved as a tiff and placed into ArchiCAD using the Figure Tool. Next is the process of getting the placed drawing to scale. I use the line tool to measure the graphic scale and resize the placed drawing in the info bar.
What I'm asking for from ArchiCAD is the ability to use the figure tool to place drawings at a given percentage instead of the feet and inch size for the placed drawing.
formZ allows for placing a drawing at a given percentage of the original drawing. This way I only need to determine the percentage once for all of my placed drawings. AutoCAD has a feature that allows the user to resize a placed drawing by measuring the graphic scale on the drawing. Either of these methods are faster that the trial and error method that I presently use to place scaled drawings in ArchiCAD.
Thank,
John
2005-06-11 09:15 PM
