Wishes
Graphics Override Components
insideru
I wish we could GO components of elements. I create many QA GOs, to be able to check different quality standards are met. Sometimes it would be really useful if i could GO components from Composites or Complex profiles, to check for continuity and proper building material assignment.
Example: GO all elements to white material, all wall insulation to red and all waterproofing to blue, then just make some marquees and visually check for continuity.
ARCHICAD 27 INT
macOS Sonoma
2 REPLIES 2
Lingwisyer
Guru
Please use the search function before creating new posts, there are a lot of wishes for this. That is one thing that has improved with the new forum... which will get even better once more posts have labels. Here are just a few;
https://community.graphisoft.com/t5/Wishes-forum/Graphic-Override-for-skin-types/m-p/242336
https://community.graphisoft.com/t5/Wishes-forum/More-amp-better-GRAPHIC-OVERRIDE-options/m-p/244157
https://community.graphisoft.com/t5/Wishes-forum/Graphic-Overrides-for-individual-parts-of-complex-p...
https://community.graphisoft.com/t5/Wishes-forum/Better-controls-for-Graphic-Overrides-for-replacing...
Ling.
insideru
Thanks for pointing this out.
The new forums are a bit of a headache for me, but i promise i will learn how to use them 🙂
ARCHICAD 27 INT
macOS Sonoma
Learn and get certified!
