2024-03-07 02:04 AM
Expanding MVO (Model View Options) to cover all elements, allowing users to switch between Local Settings and MVO for uniform control, would significantly enhance workflow efficiency. Currently, some objects support this, but extending it to all tools, including native ones, could offer more consistent and streamlined control.
For instance, the Mesh tool benefits from individual settings like Ridge Selection, yet integrating these into MVO would allow for global adjustments across different view types. Perhaps theres also room for incorporating Projection settings into MVO. For example Roof/Slab Outline settings in one view vs the next.
2024-03-07 05:27 AM
An excellent suggestion. I would also like to see quick access to the line parameters used by MVO in order to quickly change them.
