Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Inject Multi-Line dimension text into another dimension
Too Long
AS the title says please.
AC26 AUS Full
4 REPLIES 4
BrunoH
Just copy / pastefrom one to the other.
ArchiCad 3.43 to 26
MacOS Monterey
Erwin Edel
For level dimensions, we've been using this trick for years:
  1. (if it is a different dimension string): drag a copy of the original string, set it to 'static', copy and paste it to your other section/elevation.
  2. select the text that needs to be the same and then select the original text in your copied dimension string
  3. type something and remove it with backspace
  4. the new dimension should now have all the text
Not sure if this also works for 'regular' (horizontal) dimensions, since we never change the text there.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Ha.....lol.
OR
They just make this software be more consistent and work as the users suggest it should.
Archicad 23/25/26 NL , MacOS 13.4.1 (c) on MacStudio M1 Max
Thanks for reminding me again to not offer work arounds to people making wishes for functionality not implemented yet.
www.leloup.nl
Windows 10 Pro
