Wishes
Junction Order for Slab Tool
It would be great if the slab settings contained "Junction Order" so one could control the intersection of equal priority building materials at the intersection of a slab and, say, a wall.
3 REPLIES 3
Isn't that already the case ?
Don't the materials fulfill this function ?
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
"Quality is never an accident ; it's always the result of an intelligent effort" John Ruskin
They do if they are of different priority, but if its the same material or a material of the same priority, I'm trying to find a way to order the intersection so that Material A of the wall abuts Material A of the roof, not the other way around.
Erwin Edel
As a workaround, we have several different intersection priority versions of the same building material, to better help with these types of intersections.
Especially for wood, plywood (and similar board materials) and concrete these are handy to have.
But also for insulation it is good to have relatively high and low priority versions.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Learn and get certified!
