Wishes
Kitchen cabinets; additional parameter
Would be nice if the International library parts included in the "Kitchen Cabinets" all had a parameter added for the Toe (Skirting) to be able to set the depth of them.
As it is now, the included cabinets' skirting have 2 separate depths in this folder; either 0,52 or 0,57 deep?!?
Considering that there are many countries with different set of standards for these things, it would be helpful if GS added this parameter to all of the kitchen cabinets to the next version.
It makes the design process easier ....
2 REPLIES 2
Aussie John
i dont know the script, but it should be easy to change. Probably just one item in the 3d script.
Make a copy of the library part and open it.
Look for a value that represents the current value (in 3d script), change it to what ever you wish. A little trial and error goes a long way in GDL
Cheers John
[/size]
Hi John,
Thanks for the tip, but my point is that it is better if GS makes a change so that the whole AC world can take part of it. It also makes it easier when localising the program in the different countries if it is changed in the original version
Learn and get certified!
