Wishes
Lathed Column
Column object would use any complex or composite profile as a half cross section that is swept about the reference point of the column on the z-axis (or maybe any specified 3d slope).
-user could specify number of sides from 3 up.
-core and finish component toggles in profile would correspond to structure and veneer in column settings
5 REPLIES 5
Djordje
Ace
As a workaround, use Profiler or a wall with the appropriate Custom profile
And ... posting a screen shot for clarity would not be too bad
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Yes, you can draw a 1" diameter wall, set the offset from reference at 1/2" and you'll basically get the same thing.
jp
The workaround with the wall tool is tedious and doesn't yield good results. I vote for having it part of the column tool. Currently I make my own gld revolved object or square. The profiler tool has some funky results too.
Many Thanks, JP
John Peterson, AIA
Dalgliesh Gilpin Paxton Architects
Archicad 7-21 US
PC and iMac
I say: Lathed Objects in general.
Bruce
The complex profile tool works perfectly for me. You just need to offset the origin so you can describe a circle.
Bruce Walker
www.brucepwalker.com
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5003 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
