Wishes
Layer tree structure
henryL
Hi
i think the new archicad 26 layer folder organization is  just overcomplicated. It is not a real organization but jus a filter based on the parent folder and it cannot offer a granular control over the elements ( i cannot see the full tree but i have to search by name, an then move to the folder by right click in the search result). Why it have to be so complicated? Why two sub windows ? Is it possible to have a real layer tree organization like other softwares? Does the developer have ever look at the object palette in cinema4d  or rhino ? Please users and developers (if any ) see the attached image and  share your opinion.
3 REPLIES 3
DGSketcher
Legend
You're not suggesting GS follow well established standard data management interface systems are you? 😉
IIRC it was there in the initial options, but someone must have decided it was too complex to code.
Gabor Almasi
Hi Henry,
Thanks for pointing this out. We are already working on a UI where the folder structures and the attributes can be handled in a more intuitive way. It is also mentioned on our Roadmap: https://graphisoft.com/product-roadmap/in-progress.
Stay tuned,
Gabor
Gabor Almasi
Senior Product Manager
GRAPHISOFT
henryL
Thanks Gabor, sometimes i forgot that layers are attributes.
Learn and get certified!
