Wishes
Level dimension to display multiple elevation values
Achille Pavlidis
It is time for AC to provide a level dimension tool that can display elevation values for slabs made of complex profiles.
This level dimension should work to be able to display both the top and bottom of both the whole structure of only the core, and it should work for Slabs, Roofs and Shells since any of these three could be used to model composite slabs.
Mac OSX 13.6.6 | AC 27 INT 5003 FULL
1 REPLY 1
I second this and would add the ability to control the side/face (top bottom)of the roof/shell/slab/mesh etc., this would be extremely helpful when creating RCP. Particularly for those of use that model more exotic spaces.
It would be ideal to use a document tool to ....document, rather than having to disable 'live' features and using it as a text marker with custom info.
Learn and get certified!
