Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Levels
alemanda
It would be very useful and click/time saver to have the chance to chose the orientation of the triangle when inserting single levels, like when you place dimensions.
Archicad should give you the possbility to chose the orientation before placing the triangle, before last click.
I know it is possible to change after ... but doing it before placing would be faster in my opinion. The position of the pointer when the hammer appears shoudl determine the orientation of the triangle.
AC 19 and AC21 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
1 REPLY 1
alemanda
Or the pet palette should have another command to switch the orientation of the triangle (upward or downward)
Win 10 Pro 64bit
www.almadw.it
