2007-11-12 06:10 PM
2007-11-16 05:02 PM
2007-11-16 05:19 PM
aggie463 wrote:My guess is that you can't use a "paper thin" mesh for this. After all, that isn't a solid, which I believe are required for Solid Element Operations. I could be wrong, but I think that's it.
Funny this discussion would be going on now as this is exactly the main issue in a project I am working on. I like the idea of the SEO method enough, but I must be doing something wrong, as when select the thickened mesh as target and copied thin mesh as operator then subtrction with downwards extrusion then execute, nothing happens, however, doing the same thing with ANY other element works fine. Ive tried slabs, walls, etc all of which will work but not the mesh...is there a step im missing?
2007-11-16 10:18 PM
After all, that isn't a solid, which I believe are required for Solid Element Operations.yep, that's exactly right...
2015-06-10 09:06 AM
2015-06-10 12:54 PM
2016-04-10 10:27 PM
