Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Mesh with level lines option
I wish the Mesh tool had the option to choose between having the normal mesh or a level line relieve where we could pick the steps. ie: every 1m or every 5m. It is the opposite of the smooth appearance.
I know we could do it with the Slab... but this would be more helpful within the mesh tool.
Why? The slab tool seems just fine for this. At least to me.
Sometimes we don't get the contour lines properly designed by the surveyor, so we have to guess. If we had that on the mesh tool we could altomatically have the option of choosing instead of doing the same hill twice, once for schematic and another for Construction Documentation.
Another advantage is that you could simplify your working by elevating only the some lines and the MEsh tool would automatically interpolate the heights and give you the level lines...
See this post - it may help.
http://archicad-talk.graphisoft.com/viewtopic.php?t=27936
Roberto Corona was kind enough to create a GDL object that can be found in the Depository in this forum (General section).
