Read more
Wishes
More Selection Sets Options
Good day everyone,
Would it be possible to add more selection properties to the Selection Sets function?
Specifically being able to change the surfaces of multiple objects at once, as well as
being able to change on which stories they display.
Kind regards,
Zeelie
1 REPLY 1
Podolsky
Ace
There is interesting tool exists called "Surface Painter". It let to pick up Surface in 3D and after select elements in the project with same surface. Then you can use override function to change the Surface.
Also there is function, that let you change home storey for selected in 3D elements.
