When you draw a slab, and then pick a point from the perimeter, and drag it you actually create a node. Then all actions on polylines are possible.
I would like to be able to add points AND edges in all 3d archicad objects.
And of course move them , curve them... and so on.
Then i could propable do almost everything in AC.
Yes i know its sound like sketchup, but it is almost a must
I guess this would stamble at the current format of AC, but sometime the definition of objects should advance.
I guess to achive that they have to treat each object (wall, slab, roof) as a general 3d object, cause that way they can add point and edges.
