Wishes
OS "windows" to maintain View Settings
Stress Co_
Is it possible to have a "window" (O.S., not an Archicad object) maintain the View Settings for that window.
With more than one window open, each a "View" with a different layer combo, If I switch between windows... I have to reset the layer combo to correspond to that window's view ("quick options").
Marc Corney, Architect
Red Canoe Architecture, P. A.
Mac OS 10.15.7 (Catalina) //// Mac OS 14.2.1 (Sonoma)
10 REPLIES 10
Rod Jurich
Marc, you can vote also
All the best to everybody for '08.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Stress Co_
Rod wrote:
Marc, you can vote also .
Done.
Cheers Ron
-Marc
Thomas Holm
If you use the Navigator's View Map to switch between windows, you won't have that problem. It will use your set layer combo for each view/window. And it's a lot faster too.
On a side note, I read somewhere that if you edit the poll captions, GS will disregard your poll.
Link
I think you've misinterpreted the problem. Marc wants to avoid double clicking on views all the time and would prefer a simple switch by clicking on open windows.
I see your point Marc, but wouldn't this also create as many problems as it solves? A lot of the time you would want to keep the same settings when flicking between windows.
If GS let us open multiple plan windows and gave us a keyboard shortcut that toggled between keeping the current layer combo and existing layer combos, we'd be in good shape!
Link.
PS. I think Thomas is correct about the Poll options. I'm sure there's rules written about that somewhere...
Thomas Holm
Sure Link, I realize what he wants, but as he wrote 'I have to reset the layer combo' I thought it possible that he wasn't aware of the easier method to use the Navigator's View Map to switch between open windows. Some think it's only for opening new ones.
I do agree on your other points though.
Stress Co_
Sorry Thomas.. Link got my meaning.
And me yours … Just give us the option.
YES
By reset I meant using "quick options" to change the layer combo. I use the view map too, but it has the disadvantage of re-zooming to the view's “saved” zoomed area. Clicking the window is much faster (well.. if not for reseting layers).
You don't have to memorize a zoom with a view...in the View Settings, select "None" for Zooming.
Karl
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Stress Co_
Karl
True... BUT, saving the zoom solved my issue of re-zooming twice when opening a large View (it's never where I needed it). I want my cake and to eat it too.
Thomas Holm
Well, I never managed to fix that one
Learn and get certified!
