Hi- I certianly accept that ArchiCAD will never be the same as AutoCAD (thank God!) - but even after years of using it, I find certian things such as this less elegant than they should be - because too many prerequisites are required be to set up for what should be a trivial one or two click operation in any context:
You have to have already selected arcs or lines to trace with, you have to stop and select select a different tool every time for lines, arcs, polylines, fills etc (rather than just offsetting whatever element type is selected by default) , in fiddly areas you have to ensure there are no intersecting objects to curtail areas or select really really precisely , you have to retype the offset every time if doing the same offset for a range of different elements, or if want to multiply offset arcs etc,
Space click can't deal properly with ellipses or splines at all , because these are not arcs or straight lines
These are not things that being "different" justifies in my opinion, especially when offset is one of the most commonly required operations.
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-27 | Twinmotion 2023
Windoze 11 PC | Intel Core i9 10900K | Nvidia Gforce RTX 3080 | 32 Gb DDR3 | 2x4K monitor extended desktop
