Read more
Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Option to choose Reference Plane for Roofs
snow
Ace
Hello all,
We need such option...
...for Roofs as well... so urgently
To do correct construction in case of different pitches...with only and always the pivot for pitch on the lower plane... sometimes causes a lot of auxiliary lines etc.
Even mostly, we need the pivot and reference height on the upper plane.
Changes of thickness are mostly on the underside.
ARCHICAD for Future
archicad versions 8-27 | mac os 13 | win 10
5 REPLIES 5
snow
Ace
meanwhile...
Remembered, working in section etc., that by pitching with the mouse at the upper plane, the pivot seems to change upwards.
At least something... for now... 🤔
...and something else (I won't rise a separate 'wish' for this):
It was helpful to see the pivot in section/elevation projections.
ARCHICAD for Future
Julio C Freitas
It makes sense, especially since we don't have a dedicated tool for ramps. I imagine most use the roof tool to model ramps. And the reference plane underneath doesn't make much sense on this occasion, as you said, for any changes in thickness.
Long-time wish:
https://community.graphisoft.com/t5/Wishes/Reference-Plane-options-for-Roofs/m-p/225150#M14121
...even more reason to bring it on top... in remembrance again... and to underline the urgency...😉
ARCHICAD for Future
Roderick_Anderson
I will add my vote to this as well !
