Wishes
PM9 Text Leading Bug
I wish I could change the leading distance of a text that is already on a layout, master, or master PMK. Right now, you can set the leading when you first add the text, but you can't go back and modify it at all -- you have to delete the existing text and add a new text to get the leading you want. ArchiCAD 9 doesn't have this bug.
3 REPLIES 3
Aussie John
Jay I might be misunderstanding you but it works fine for me
Cheers John
[/size]
I tried it again and found that if I use the up/down arrows to set the leading size to 75, then click the OK button, it doesn't work properly. But if I type the number in, or click into some other box before clicking OK, it works just fine.
Apparently I was always clicking the arrow, then clicking OK.
Aussie John
That worked for me too!!!
dont worry I have a text bug that send the edit box full width of screen but only happens randomly
Cheers John
[/size]
