Got a minute? We appreciate your feedback:
Graphisoft Learn survey
Wishes
Perspective Distortion Correction & 3D update before render
concepsys
Perspective Distortion correction & 3D model update before rendering must be available both in Saved 3D views and in Camera path.
While Camera Paths have this update 3d model before rendering that allows objects in the model to face the camera in every view, they don't have perspective distortion correction.
When rendering a set of saved 3d views in a layout, for instance, the first image is ok, but the next images have the objects skewed because they didn't face the camera in every view.
These two options should be together and be available both in 3D image settings as in Path/Camera Settings. This is very important to make publishing renderings easy. Until then it is still a manual process of updating every 3d model before rendering its image.
0 REPLIES 0
