2020-02-10 03:53 AM
2020-02-10 04:01 PM
2020-02-17 08:06 PM
2020-02-18 02:33 AM
jl_lt wrote:
Maybe a selection hierarchy list could be useful
2020-02-20 07:43 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-02-21 02:33 PM
2020-02-28 04:20 AM
2020-03-16 05:09 PM - edited 2022-05-03 05:13 AM
I think that what Mr. Tomek is talkin about is that sometimes you have something in your drawing or view that is already set and should not move again, but you still want to keep seeing it while working yet it actually interferes with your selections everytime you click on it (section markers with distance are particularly cumbersome on this). So i think what he is asking for isa n option to remove locked objects out of the selection cycle without turning them off. Personally i would find this quite useful
2021-02-05 04:12 AM
DGSketcher wrote:You toggle the toggle so that you can select locked elements
Ok, you have your toggle, what happens if you want to unlock the Locked element?
2022-05-02 11:39 PM
Hi! two years are gone already, but this function is still not available...i'm working on a project where the terrain mesh is gigantic and locking the specified layer is not enough...every single mouse click will select the mesh and as you can image, is impossible to work on it!! please make it happen!!
