Wishes
Project Info in Publishing Set
Pato99
I deleted a previous thread about having the ability to publish in text formats, I thought it was too complicated.
I'm simply asking now for the 'Project Info' to be available in the Project Map. That way it can be transferred into the Publisher Set to be published as an XLS or List file and added to a database later on.
It's important that it's in the publishing set as in my personal experience the Project info changes throughout a job and it's not viable to manually export each time.
Versions 10 to 27
Metabox Prime-X P775DM2-G (Clevo),
GTX 1060 6GB GDDR5 VRAM - G-Sync,
i7-6700K (8M Cache up to 4.2 GHz),
32GB DDR4 2133MHZ,
512GB SATA 3 M.2 SSD,
Win 11 64
0 REPLIES 0
