Wishes
Redefining Project Preferences
It would be great if you could redefine your project preferences for dimensions instead of constantly having to add new ones. Having the ability to redefine instead of having to add new ones would save time if you have to change many viewsets view setting at one time.
2 REPLIES 2
David Maudlin
Emily:
There is a method to redefine Dimensions, but it is more complex than it should be:
1. Note the name of the Dimension Standard you want to alter.
2. Delete this Standard (the Standard should now read "Custom").
3. Change the dimension options.
4. Click the "Add..." button and enter the exact name of the old Standard.
5. Your Standard should now be changed to the new dimension options in the Views.
The method of redefining a Dimension Standard should be easier and more transparent, like changing a View attribute, unless someone knows of a better method than I have described.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
compu
A "Store As" button, than an "Overwrite" would be fine, such as redefining at "Model View Options".
archisem.com
Learn and get certified!
