2003-12-24 06:55 PM
2003-12-24 07:43 PM
2004-01-05 09:11 PM
Geoff wrote:Very good idea! This would eliminate nearly all custom dimensions, with the exception of those times that changes don't warrant altering the model.
On a related note, a lot of custom dimension values would be unnecessary if you could:
A) add leading and trailing text to calculated values , for things like TYP., R.O., ±, etc.
B) adjust the rounding (and units) on a per dimension basis so you could avoid pesky fractions/decimals in selected circumstances without having to alter the accuracy of the entire file.
2004-01-05 10:19 PM
