2006-07-25 09:52 AM
2006-07-25 11:07 AM
2006-07-25 01:00 PM
2006-07-25 06:35 PM
2006-08-11 10:41 PM
andrewzarb wrote:For me, this issue (the inability to save to Artlantis 4.5) came when I was in a hurry. Fortunately I had not used any exclusive feature of Arch10 in that project, but I did use Arch10 library parts, which I had to replace once in Arch9.
Of course it's possible, unless you,ve used slanted walls, slanted columns, beams which are pitched, openings in polygonal walls... what else is new in ten?
The advances in artlantis are great but not a an issue to whether ArchiCAD CAN save to 4.5 which it should considering that it can save to so many other formats.
The question is whether Abvent or Graphisoft indipendently or colaboratively have decided not to support 4.5, which obviously only helps Abvent and could be seen as a dirty trade practice.
2006-11-18 01:42 PM
2006-12-12 03:58 PM
Ciiku wrote:Add-on export from ArchiCAD 10 to Artlantis R and Studio:
has anybody found a solution to this
2006-12-12 08:38 PM
andrewzarb wrote:Well, even if Abvent is all too familiar with dirty trade practices, Artlantis R is SOO much better than 4.5. Upgrade!
