Wishes
!Restored: Uniform scale menu
Anybody else bothered by the fact that the scale menus in plotmaker and archicad are reversed. One increases in drawing scale the other decreases. I'm constantly looking in the wrong place for the correct scale.
Can we get the menus to match?
9 REPLIES 9
Rob
Millard,
I am sorry, I don't understand what you are talking about???... scale menus???
::rk
Archicad scale menu
Plotmaker drawing scale menu
__archiben
i'm more bothered that the scale button in the window status bar doesn't pop-up automatically - it displays a window with . . . . a pop-up list. graphisoft just love to wear out our mice with this and many many other similar instances on the UI . . .
~/archiben
b e n f r o s t
Rob
Millard,
it doesn't seem to be a problem in metrics.
::rk
TomWaltz
The only good thing about the pop-up is if you need a custom scale, but that could be limited to ONLY if you need a custom scale.
Tom Waltz
__archiben
exactly - 'custom' is not an insurmountable problem for a pop-up list.
~/archiben
b e n f r o s t
David Maudlin
Millard:
Your screen shot from PlotMaker shows the pop up list for Title Types, not the scale (which can be seen in the lower right of the image). The order for the Title Types is the same as their order in the Title Types folder in the Navigator. The scale pop up lists in ArchiCAD and PlotMaker are in the same order.
Hope this helps.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Thanks David,
That does help. I never thought about that it was just the list of title types that was out of order.
Learn and get certified!
