2005-02-18 05:22 PM
2005-02-18 05:51 PM
Haneef wrote:Take a look at Introduction to Object Making; Go to the Help menu/ArchiCAD Help.
I currently manually edit the GDL script, adding rotx, roty & rotz when required (eg. in custom roof vents). If there was an option to add this automatically, it could save a lot of time. Less GDL knowledge may be required (which is not necessarily a good thing, but I know in South Africa, Revit's ad campaign against Archicad was that "Archicad was a good program, but users had to know gdl programming to use it properly")
2005-02-19 02:52 AM
Haneef wrote:i think that you are correct in your intentions, but i would suggest the there needs to freeform translation available for all (most?) elements at the
I would like to see an option to automatically add some rotation commands to all custom objects.
2005-02-20 06:51 PM
~/archiben wrote:This is how it should work and it is a must for a true 3D architectural work environment, I will not mention other packages....
..... i would suggest the there needs to freeform translation available for all (most?) elements at themodelling levelnot automatically built into each object/element.
this way we can forget about having to specify the angle parameters, or build in intelligent hotspots, etc. because archiCAD would do all of the rotation in 'model space' for us . . .
just a thought?
~/archiben
