It would be great if you could insert doors INTO the curtail wall and have a smart
automatic
handling of the door frames and curtain wall frames. I was able to get the curtain wall doors to schedule with my regular doors but the don't appear to use the same parameter for width, height and panel thickness so for some folks that would be a deal breaker. For a project with less than a dozen or so doors inside curtain walls I think you can do what I like to call "digital white out" for those particular incompatible fields in the layout environment. A workaround, but still faster than creating the entire thing by hand.
matt johnson
archicad since 2004
imac 27, 4.2 GHz Intel i7, 16 GB RAM, radeon 575 4 GB, macOS 10.14.6
imac, 4.0ghz i7, 16gb ram, Radeon M9 390 2GB, OS X El Capitan
