If the section marker head is set to be in the middle, then you can drag it with a pet palette option.
The range will stay where it is and the marker goes where you want.
If the marker head is set to the ends, then you can't drag them but you can link to another section line.
So place two sections and change one to a linked marker and link it to the real section.
You can place the real section in a layer that is turned off so you don't see the markers and then move the linked section to where ever you want.
Versions 6.5 to 25
