Wishes
Section views
KeesW
Section views:
Is it possible to have elements which are obscured by closer objects, show as a dashed line?
Cornelis (Kees) Wegman
cornelis wegman architects
6 REPLIES 6
Not presently, but this has been requested before. It seems that it might be rather complex to make it work in a way that would be easy to manage.
KeesW wrote:
Section views:
This can be done via the Special menu. Enable the menu on startup or permanently. Windows procedure is here:
http://www.graphisoft.com/community/archicad-talk/viewtopic.php?p=2411#2411
Enable special lines - screenshot below....continue with next post and screenshot there. I learned this on this forum, but can't seem to find the original poster (Djordje perhaps?) via search.
Karl
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
(Part 2)
Click the Special Hidden Line menu item next to get the dialog shown below and make invisible lines dashed. Rebuild the section, and hidden lines (within the section depth) will show up as dashed now.
It even 'understands' the new 'distant' area and will use the 'distant' pen to mark distant hidden objects with that pen color - and the line type chosen in the dialog below.
AFAIK, special menu settings do not get memorized with views, so linking to views that require these special lines - or even publishing such views - would not be very automatic. Perhaps the wish should be that GS implement these options as full-fledged display options that are memorized with views rather than leave them hidden in the special menu.
HTH,
Karl
Djordje
Ace
yes, in the Special menu. Karl already explained, with screenshots
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
tsturm
Can someone post the process to make the Special Menu visible for a Mac OS X user. I was able to get this done using OS 9. But now that I have OS X. I cannot find the right method to turn on the menu. Can anyone help out?
Terrence Sturm, Architect
_______________
MBP OSX 10.15.4 Quad Core Intel i7 2.2hz
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
hold down apple and alt when starting archicad
