Wishes
Skylight tool - 2D representation
The Skylight tool must be represented in the same way when used with Roof tool and Shell tool and have the same options for adjustment!
The picture shows the 2D representation of the same Skylight, used with Roof and Shell, which is entirely different! Adjustments for 2D representation, symbolic or realistic view and scale sensitivity are entirely different too!
Only in 3D one can recognize it is the same Skylight!
2 REPLIES 2
With shells you can do the walls and roof. I think there should be a choice of two types of 2D form for Skylight.
The symbolic view is available only with Roofs. The Shells offer different kinds of simplified views, whish are always cut on plan.
But the idea is that the tools should always behave in the same way regardless of how they are used!
