Hobbesnb wrote:
Does anyone know where the Built in Story Marker object is located in the AC library (V.11)?/..
First you have to add to your WE a menu item - "Open Object by Subtype".
Then you can select to open as such and edit the marker you choose.
You will not be able to overwrite the default, you will have to save as, with new name.
When setting the default maker to use, you will find an odd thing happening.
If you wish to change markers, you first have to select " No maker "
then select the marker of choice in order to have your default parameters
selected as set when you save the marker.
Clear as mud
Rod Jurich
AC4.55 - AC14 INT (4204) | | OBJECTiVE |
