Wishes
Text Codes For Locating Details/Sections
I would like to see codes added to text or labels so that I can point to specific details or sections. For example, we often have labels that say something like:
"...SEE DETAIL 3/A305"
It would be nice to be able to link to the detail with some kind of code system like:
"...SEE DETAIL <D01:PmADrNo>/<D01:PmAShNo>"
1 REPLY 1
Geoff Briggs
Mentor
You can kludge this now, see Alex's tip at http://archicad-talk.graphisoft.com/viewtopic.php?t=625. But clearly this should be possible entirely within ArchiCAD. Auto text is creeping it's way into other tools (check out the little pull downs when you select the text in a level or elevation dimension). Your suggestion is one of the most useful and is needed to close the loop now that we have titles and auto-numbering in PM.
Regards,
Geoff Briggs
I & I Design, Seattle, USA
AC7-27, M1 Mac, OS 14.x
Learn and get certified!
