It would save a bunch of time if labels and text (for notes, etc.) would automatically be on top in reference to the display order. It is time consuming to put the note in, undo, redo so it's highlighted, then go to display order to make the note on top.
Or at least put in an option for it in the default settings.
Tom wrote: AHA! Any way to make them first among equals?
I don' think you can change the hard-coded default order.
I usually select all Text and Labels and bring them all to the front. That's my solution, it is fast to do.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac27
