I would like the ability to independantly adjust the origin & alignment of materials on each face of an entity - currently only "dominant" face of entities can be adjusted, which affects all other faces wether you like it or not.
This is hopeless eg for brick textures, where mortar joint lines sometimes cannot be made to follow consistantly up side & across top of brick walls.
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-27 | Twinmotion 2023
Windoze 11 PC | Intel Core i9 10900K | Nvidia Gforce RTX 3080 | 32 Gb DDR3 | 2x4K monitor extended desktop
