Wishes
Uniform roof pitch measurements in Tracker and Roof tool
I wish the angle measurements in the Tracker to correspond to the selected measurement method in the Roof tool when the Multi-plane roof is used.
When the horizontal ridge of the roof is stretched, the Tracker has the option to input the roof pitch for the desired roof plane. But it is only in degrees, while the roof pitch is usually measured in percents!
0 REPLIES 0
