Read more
Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Vehicle tracking
TimATAD
We work in the motor industry and part of our work involves using vehicle tracking software in 2D & 3D. Currently we have to have a full version of AutoCAD to run AutoTURN.
https://autoturnonline.com/integrated/
Why does Graphisoft not have a plug in for something like this? Using library tracking curves is not enough.
Can Graphisoft advise why they don’t have a link to a dedicated tool, this must be a requirement of other designers. The inclusion of this would mean that we could remove the need for AutoCAD completely.
We look forward to your help on this.
13 REPLIES 13
Miha_M
A long time ago there was a Tracking Curve Tool library object available for NZ Select and Cadimage Premium Subscribers
I believe some Cadimage Tools have been further developed by Central Innovation by the name CI Tools. The vehicle tracking curve tool is not there anymore so I guess it hasn't been updated for new Archicad versions.
| Archicad 4.55 - 27
a long time ago Cadimage offered these for free.
Think Like a Spec Writer
AC4.55 through 27 / USA AC27-4060 USA
Rhino 8 Mac
MacOS 14.2.1
Djordje
Ace
Very relevant, and very required facility. Please add to the Wishlist.
I usually have to get it done by a traffic specialist and insert the dumb 2D in the model for reference.
online autoturn works up to a point, but not fully
I still have the old NZ libraries and they work, up to a point. It is even possible to move the box model along the path and animate it within Archicad, if I remember correctly.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thanks for the feedback, we use the full AutoTurn with AutoCAD and its a painful waste of time and money, if only there was an integrated solution.
Erwin Edel
I think the problem with these things are that local norms/rules (norm vehicles) are different, making the market a niche market.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Though the curves can all be calculated if the user just inserts the relevant vehicle dimensions, which could even be loaded from a secondary file that can localised or user modified.
Tinou
And this possibility is already inclueded in Allplan since years !
Étienne - AC 24 - France
It's also integrated in Vectorworks:
Martin Luther Jules
AC 10-27 (Full)
Asus | 64 GB RAM | Windows 11
The archicad tool is very basic, clumsy & you can’t change radius mid turn, it’s a start but not good enough
