Wishes
W Triangle Fix 13
Hi, ovely triangular window but when "Top Edge From Center" changed, hole in the wall still in the middle
Is there any chance to download fixed version, or anyone know where to add "tec" to fix it?
Thanx
2 REPLIES 2
ztaskai
Graphisoft Alumni
Graphisoft Alumni
This is a bug - not wish, of course. It is already fixed in our internal code base but since the fix affects several base macros, we can't give you one file to replace. The problem will be fixed in the upcoming v14 release (and in all national v13 library updates released after November 2009).
I'm sorry about the inconvenience.
Regards,
Zsolt Táskai
ArchiCAD Development - GDL Team
AC13, AC14 and upwards...
Just updated library to LIB13-INT-3421 (dec 2009) bug is notfixed yet
Learn and get certified!
