2006-10-07 04:49 PM
2006-10-09 06:27 PM
2006-10-10 02:07 AM
Karl wrote:Thanks Karl.
Hi Jeff,
The options you want are not limited to slabs: user defined fields, etc. are only available with (most) GDL objects, which also happen to be 'zone-aware'. Columns, for example, don't have those fields.
I'd like to see a uniform treatment of all elements also, as it could simplify your request as well as other scheduling matters.
Sure, property objects or labels can be used to associate additional data with slabs (and other non-GDL elements), but the everyday user just wants a few more fields to easily stuff data into as we can do with objects.
Temporary workaround idea: I have not tried this and don't have time at the moment to play, but I wonder if you could work around your need for the moment by using a slab-associative label? It appears from the GDL manual that a label can use a REQUEST to find the zone that it is in, so if your label positions itself inside the slab perimeter, perhaps you can retrieve the slab's zone(s) from that. Of course, maybe only 3D elements are 'zone aware' and a REQUEST from a label won't return anything....
Karl
2006-10-10 06:54 PM
2006-10-11 02:14 AM
Karl wrote:Do you know a good source to help me learn ArchiForma? I own the program but find it very difficult to use and learn with little to no help provided by Cigragh. I also don't have the advantage of a friend I can watch using it. I'm sure I could pick up quickly with a little bit of help from someone who knows how to use it. The book that came with it makes my head feel like its about to explode.
Jeff,
So much for my hypothesized work-around. While you can schedule 2D objects, of which labels are one subtype, the scheduler will not include labels in any schedule. Stupid restriction IMHO - let the user filter them out if we don't want them.
So, as in the other thread where you brought up this issue, the only workaround at present is to save your countertops as objects - tedious as you say.
As in that thread, you have the choice of doing a 'save as' as an object, counter by counter. (If you do that - select all counters - easy with Find and Select based on thickness and height - and save them as a module for future editing, or stick them in another layer/etc.) Or, as Dan suggested, use ArchiForma. It has the advantage that you can round the edges if necessary to improve the appearance of renderings (at a polycount penalty, of course) and you can still edit the obects directly in ArchiCAD.
With only objects being 'zone aware', and labels not being considered objects by the scheduler, your only option today seems to be to save your countertops and trim as objects if you need a by-room schedule that is 'live'.
All elements placed by tools are treated differently by ArchiCAD from those elements that are GDL objects. Consistency is something to wish (vote) for.😉
Karl
2006-10-11 09:21 AM
I own the program but find it very difficult to use and learn with little to no help provided by Cigragh.Please just ask what you need for by sending an e-mail to my personal e-mail address (as everybody does):
2006-10-11 07:06 PM
Fabrizio wrote:Sorry, my friend. My comment sounded unduly critical of your product and company. It’s probably just me but I find the program not very intuitive and the manual hard to learn from, but like I said, that’s just probably my stupidity.I own the program but find it very difficult to use and learn with little to no help provided by Cigragh.Please just ask what you need for by sending an e-mail to my personal e-mail address (as everybody does):
fabrizio.diodati@cigraph.com
2006-10-12 09:43 AM
vincon2 wrote:You're not alone, mate
I guess what I really need is Cigraph for Dummies.
