Wishes
Wrapping of finishes
It would be nice that if when you place an empty opening in a wall that it would give you the option to wrap the composite around the opening, as you can do with "wall end". Otherwise you have to create small walls and slabs to finish off the surface.
I realize for rendering purposes you can tell it to wrap the finish but if you cut a section it doesnt actually wrap the composite...
Rob Oberle
Behr Browers Architects, Inc.
Westlake Village, California
12 Archicad Licenses
1.8 Ghz PowerPC G5/ 4GB DDR SDRAM
OSX 10.4.x/Archicad 10 (1010)
1 REPLY 1
I agree, this is a must. I've been using the work around of patches which is a poor solution at best and add a great deal of extra work when you start getting into revisions
Learn and get certified!
