Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
auto dimension to wall framing
Gus
I wish we could autodimention to the wall framing not the extent of the wall profile (if you are using a complex profile). Framers don't care about the stuff going on the outside of the wall like stucco or siding.
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W Corei7-3630QM@2.40GHz
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
27 REPLIES 27
Is "Dimension only the Core of Composite Walls" check box not working for you?
Richard
AC25 (since AC6.0), Win10
Rod Jurich
And remember to "Uncheck" the skins not wanted when doing as Richard suggests.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Link
I think the keyword here is complex profile! Not composites...
Link.
Rod Jurich
Right as usual Link.
More speed and less haste, a case of looking and not seeing.
Rod Jurich
Link
Happens to the best of us - hurry up and help!
Link.
vfrontiers
Bummer.... It's good news hearing that dimensioning works to the CORE of composites... but not to complex profile walls... The Complex Profiles editor even has the CORE checkbox, which does nothing as far as dimensioning is concerened. Apparantly we need a STRUCTURE layer in the complex profile editor!
Duane
Visual Frontiers
AC25 :|: AC26 :|: Enscape3.4:|:TwinMotion
DellXPS 4.7ghz i7:|: 8gb GPU 1070ti
TomWaltz
uh guys... dimension to core DOES work on Profiled Walls... I'm doing it all day long. (If it isn't possible, I'd better tell my staff to stop doing it!)
Tom Waltz
vfrontiers
I guess I should have said AUTOMATIC dimensioning...
Duane
Visual Frontiers
Link
uh not really, that is what the thread is about!
Link.
