Got a minute? We appreciate your feedback:
Graphisoft Learn survey
Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
fix v12 doors & windows please
I don't know if other people have run into the same problem, but when we set v12 doors to simple 2d plan symbol it displays a door swing & opening based on the rough opening rather than the door opening. the drafting standards that we conventionaly use here is that the opening show for a door on 1/8" plans is the same as the door opening not the rough opening. ealier versions of ArchiCAD doors (v11) work properly.
Also it seams there are still several problems with trim options that make the doors not useable. We have had to resort to using v11 doors and windows to get workable library pars.
6 REPLIES 6
Same here!
I use v.12 doors but have to change the parameters of the doors at some point.
Erich
While I don't use doors on that setting I vote essential. Right now ANY fix to the windows and doors in AC12 would be welcome.
Hopefully they will come before the next version of AC.
(Karl, just another whiny American )
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Could you post a screenshot of this issue?
Also, in the Internal Door Settings panel, there are Door Size Settings where you have several options on what is considered Nominal Size of the Door. Could that help?
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
The screen shoot below shows the issue with the d1 12 door in that it shows the rough opening rather than the nominal opening when set to simple. Several of the 12 doors behave this way, but the 11 doors and a few 12 doors show the correct opening when set to nominal opening size and simple 2d symbol.
I think you can play around with the four possible options that you can set to be the Nominal Size of the Door.
May work differently as AC11 as default but I think you can achieve what you want.
The lower Door in the image is now set to use the Egress Dimension as Nominal Size.
